Oldal 513 / 1053 Ugrás ide:
|◄ Első  ◄ Előző   509  510  511  512  513  514  515  516  517   Következő ►  Utolsó ►|
Rasiel | 505    2015-09-16 16:20:00 [27070]
lefordul, be is égethető, és nem csinál semmit :3
Előzmény: Rasiel, 2015-09-16 16:19:00 [27069]
Rasiel | 505    2015-09-16 16:19:00 [27069]
#include <avr/io.h>
#include <stdio.h>
#include <util/delay.h>
#include <util/sbit.h>
// LCD pinout definition
/*var
LCD_RS : sbit at PORTB0_bit;
LCD_EN : sbit at PORTB1_bit;
LCD_D4 : sbit at PORTB2_bit;
LCD_D5 : sbit at PORTB3_bit;
LCD_D6 : sbit at PORTB4_bit;
LCD_D7 : sbit at PORTB5_bit;
LCD_RS_Direction : sbit at DDB0_bit;
LCD_EN_Direction : sbit at DDB1_bit;
LCD_D4_Direction : sbit at DDB2_bit;
LCD_D5_Direction : sbit at DDB3_bit;
LCD_D6_Direction : sbit at DDB4_bit;
LCD_D7_Direction : sbit at DDB5_bit;*/
//keypad definitions
#define key_d0_dir : SBIT(DDRB,7)
#define key_d1_dir : SBIT(DDRD,7)
#define key_d2_dir : SBIT(DDRC,0)
#define key_d3_dir : SBIT(DDRC,1)
#define key_d4_dir : SBIT(DDRC,2)
#define key_d5_dir : SBIT(DDRC,3)
#define key_d6_dir : SBIT(DDRC,4)
#define key_d7_dir : SBIT(DDRC,5)
#define key_d0_out SBIT(PORTB,7)
#define key_d1_out SBIT(PORTD,7)
#define key_d2_out SBIT(PORTC,0)
#define key_d3_out SBIT(PORTC,1)
#define key_d4_out SBIT(PORTC,2)
#define key_d5_out SBIT(PORTC,3)
#define key_d6_out SBIT(PORTC,4)
#define key_d7_out SBIT(PORTC,5)
#define key_d0_in SBIT(PINB,7)
#define key_d1_in SBIT(PIND,7)
#define key_d2_in SBIT(PINC,0)
#define key_d3_in SBIT(PINC,1)
#define key_d4_in SBIT(PINC,2)
#define key_d5_in SBIT(PINC,3)
#define key_d6_in SBIT(PINC,4)
#define key_d7_in SBIT(PINC,5)
#define spkout SBIT(PIND,3)
#define spkout_dir SBIT(DDRD,3)
unsigned char lastack;
unsigned char lastnack;
unsigned char currentsyn;
unsigned char lastsyn;
unsigned char eat;
unsigned char pdt;
char passcode[4];
char newcode1[4];
char newcode2[4];
bool armed;
bool proximity;
bool commerror;
bool showzones;
bool zone0;
bool zone1;
bool zone2;
bool zone3;
bool zone4;
bool zone5;
bool zone6;
bool zone7;
bool zone8;
bool zone9;
//** Beep **
void beep()
int cycle;
for (cycle=0; cycle<255; cycle++)
spkout = !spkout;
_delay_us(80);
// M A I N P R O G R A M
int main(void)
spkout_dir==1;
while(1)
beep();
Előzmény: elektron, 2015-09-16 16:17:00 [27068]
elektron | 15859    2015-09-16 16:17:00 [27068]
Amit itt beírtam az lefordul itt, nálad mi a gond, mit ír ki ?
Előzmény: Rasiel, 2015-09-16 16:15:00 [27066]
elektron | 15859    2015-09-16 16:16:00 [27067]
#include <avr/io.h>
void beep() {
uint16_t cycle;
for (cycle=0; cycle<5000; cycle++)
PORTD=(PIND&(~(1<<3)))|(~PIND)&(1<<3);
_delay_us(1);
int main() {
DDRD=(1<<3); // kimenetre állítva a 3. bit a többi bemenet
while (1)
beep();
return 0;
Előzmény: Rasiel, 2015-09-16 15:58:00 [27063]
Rasiel | 505    2015-09-16 16:15:00 [27066]
be van dugva a cucc, de a maszkolós verzió nem fodul le....
Előzmény: elektron, 2015-09-16 16:14:00 [27065]
elektron | 15859    2015-09-16 16:14:00 [27065]
Ha be van dugva a cuccodd, meglátod szól e , persze a PORTD 3. bitet még kimenetre kell kapcsolni, az még hiányzik belőle a
DDRD 3. bitje vagy már az a programodba be van állítva az illető bit kimenetre ?
elektron | 15859    2015-09-16 16:11:00 [27064]
Ez lefordul biztos, most írtam be az AVR Studio-ba.
#include <avr/io.h>
void beep() {
uint16_t cycle;
_delay_us(1);
int main() {
while (1)
beep();
return 0;
Előzmény: Rasiel, 2015-09-16 15:52:00 [27059]
Rasiel | 505    2015-09-16 15:58:00 [27063]
Igen, na ez az a része a C-nek amit igazán nem értek. Jobb szeretem maszkolni az I/O lábakat, mivel szegény mega 328as minden lába foglalt és mivel elég bután sikerült kihozni őket így nincs csak egy teljes értékű I/O regiszterem.
Előzmény: elektron, 2015-09-16 15:54:00 [27060]
elektron | 15859    2015-09-16 15:56:00 [27062]
Ide nem kell sbit.h se. Pont ezzel játszottam tegnap a távcső vezérlőm programjában is., csak kicsit még tompa a fejem, de majd belejövök estére.
Előzmény: elektron, 2015-09-16 15:55:00 [27061]
elektron | 15859    2015-09-16 15:55:00 [27061]
Olvasáskor a PIND-t kell olvasni, íráskor meg a PORTD-re kell írni. Én itt byte formában csináltam meg. a toggle funkciót.
elektron | 15859    2015-09-16 15:54:00 [27060]
PORTD=(PIND&(~(1<<3)))|(~PIND)&(1<<3));
na ez elvileg megfordítja a bitet, ha jól írtam meg.
Előzmény: Rasiel, 2015-09-16 15:43:00 [27052]
Rasiel | 505    2015-09-16 15:52:00 [27059]
Előzmény: n/a (inaktív), 2015-09-16 15:49:00 [27057]
Rasiel | 505    2015-09-16 15:51:00 [27058]
ott a pont. ez volt a baj, most az SBIT utasításra rinyál, valahonnan le kell vadászni hozzá az sbit.h-t
n/a (inaktív)    2015-09-16 15:49:00 [27057]
És szerintem a pin definíció sem jó, persze ebben lehet tévedek, mert nem ismerem az AVR studiót, de sztem így kéne:
#define spkout SBIT(PORTD,3)
Előzmény: Rasiel, 2015-09-16 15:44:00 [27053]
n/a (inaktív)    2015-09-16 15:48:00 [27056]
pontosvesszők hiányoznak sorok végéről.
A függvényednek int a visszatérési értéke, de nem ad vissza semmit.
void beep()
int cycle;
spkout = !spkout;
_delay_us(80);
elektron | 15859    2015-09-16 15:46:00 [27055]
Imádom a C nyelvet, csak tudni kell pár dolgot, ami lényege.
lazi | 1490    2015-09-16 15:45:00 [27054]
Ízlések és pofonok
Basicben kb. 6 sor volt egy 30000-ig kijelző fordulatszámmérő, C-ben ez kicsit macerásabb.
Ha muszáj a sebesség akkor C és Assembler, ha mindegy akkor egyszerűbb a Basic.
Előzmény: n/a (inaktív), 2015-09-16 15:26:00 [27046]
Rasiel | 505    2015-09-16 15:44:00 [27053]
//** Beep **
int beep()
int cycle;
spkout = !spkout
_delay_us(80)
Előzmény: n/a (inaktív), 2015-09-16 15:42:00 [27051]
Rasiel | 505    2015-09-16 15:43:00 [27052]
Procedure Beep;
Var
Cycle:Byte;
Begin
For Cycle:=0 to 255 do
Begin
PortD3_bit:= not PortD3_bit;
Delay_us(80);
End;
End;
Ez az eredeti kód. ezt próbálom átszenvedni C be.
Előzmény: n/a (inaktív), 2015-09-16 15:40:00 [27050]
n/a (inaktív)    2015-09-16 15:42:00 [27051]
Valahol sztem hiányzik egy pontosvessződ a sor végén, másold be a kódot ahogy most van.
Előzmény: Rasiel, 2015-09-16 15:39:00 [27049]
n/a (inaktív)    2015-09-16 15:40:00 [27050]
Még annyi, hogy ez így egy 1Mhz-es jel lesz 255usec hosszú, ha ezt egy piezo buzzeren akarod hallani, az nem fog menni. tegyél be több várakozást a ciklusba.
Előzmény: Rasiel, 2015-09-16 15:26:00 [27047]
Rasiel | 505    2015-09-16 15:39:00 [27049]
ugyanaz....
33 expected '' before ':' token
32 expected primary-expression before ':' token
Előzmény: n/a (inaktív), 2015-09-16 15:36:00 [27048]
n/a (inaktív)    2015-09-16 15:36:00 [27048]
Az spkout változót ha jól látom egy bitnek definiáltad. A ~ operátor szerintem csak byte vagy int stb. változókon negálást csinál, szerintem ez biten nem fog működni, igaz nem ismerem az AVR studiót, de sztem ez lesz a probléma.
próbáld meg bit invertálással:
spkout = !spkout;
Rasiel | 505    2015-09-16 15:26:00 [27047]
#define spkout : SBIT(PORTD,3)
#define spkout_dir : SBIT(DDRD,3)
int beep()
int cycle;
spkout = ~spkout
_delay_us(1)
rá van kötve egy piezzo az egyik lábra, és ha meghívod az eljárást, akkor idegesítő hangot ad.
bocs, pascalos vagyok, de sajnos váltanom kell.
spkout = ~spkout < itt akad el.
Előzmény: elektron, 2015-09-16 15:19:00 [27043]
n/a (inaktív)    2015-09-16 15:26:00 [27046]
Éppen ezek miatt a dolgok miatt átlátható a C nyelv.
Előzmény: lazi, 2015-09-16 15:25:00 [27045]
lazi | 1490    2015-09-16 15:25:00 [27045]
No pont az ilyenek miatt rühellem a C programozást.
Előzmény: n/a (inaktív), 2015-09-16 15:22:00 [27044]
n/a (inaktív)    2015-09-16 15:22:00 [27044]
Javítva a fgv.:
int beep()
int cycle;
for (cycle=0; cycle==255; cycle++)
spkout = spkout;
_delay_us(1);
A hiba a for ciklusban van, a feltételnél két egyenlőség jel kell, mert összehasonlítás.
A másik hiba a spkout == spkout;, ennél egy egyenlőség jel kell csak, mert értékadás.
Igaz az spkout = spkout; sornak nem nagyon van értelme, hogy egy változó felvegye önmaga értékét, ez a sor így nem csinál semmit...
elektron | 15859    2015-09-16 15:19:00 [27043]
for (cycle=0; cycle=255; cycle++) helyett
for (cycle=0; cycle<255; cycle++) ez akarna klenni gondolom.
Na most megyek a boltba addig nem tudok segíteni míg vissza nem érek ...
Előzmény: elektron, 2015-09-16 15:17:00 [27041]
elektron | 15859    2015-09-16 15:17:00 [27042]
meg a végén se a pontosveszsző, de ez mi akarna lenni ?
"spkout == spkout"
elektron | 15859    2015-09-16 15:17:00 [27041]
#define spkout_dir SBIT(DDRD,3);
int beep()
int cycle;
spkout == spkout;
_delay_us(1);
De ez mit is akrna csinálni ? Ott az a kettőspont nem kell az első sorban.
Előzmény: Rasiel, 2015-09-16 15:10:00 [27039]
lazi | 1490    2015-09-16 15:15:00 [27040]
For ciklus sorvége pontosvessző (szerintem, rég írtam már C programot)
időzítést is növelheted első körben, jobban észreveszed a történést
első sorban kettőspont jó?
Rasiel | 505    2015-09-16 15:10:00 [27039]
#define spkout_dir : SBIT(DDRD,3);
int beep()
int cycle;
spkout == spkout;
_delay_us(1);
És nem fut le....
Error 34 expected '' before ':' token
Error 33 expected primary-expression before ':' token
Rasiel | 505    2015-09-16 15:02:00 [27038]
köszi!
Előzmény: elektron, 2015-09-16 15:00:00 [27037]
elektron | 15859    2015-09-16 15:00:00 [27037]
Példák
Előzmény: elektron, 2015-09-16 14:46:00 [27036]
elektron | 15859    2015-09-16 14:46:00 [27036]
Azt hiszem e a fordító van benne: http://gcc.gnu.org/
Példákból lehet tanulni, az egyszerűbb.
Előzmény: Rasiel, 2015-09-16 04:52:00 [27029]
forgácsolo | 2703    2015-09-16 13:49:00 [27035]
felhívtam a forgalmazót és az anyag megkötés után nem szép egyenletes felületet ad, buboréknyomok maradnak, nekem sima felület kellene mint a nikecel stukkóknál
Előzmény: vjanos, 2015-09-16 10:56:00 [27032]
zoli0302 | 387    2015-09-16 12:57:00 [27034]
És nem is drága, kb 5000 Ft/kg
Rabb Ferenc | 4387    2015-09-16 11:09:00 [27033]
Szintén poiuretán. Szinte tetszőleges forma készíthető belőle
Előzmény: forgácsolo, 2015-09-16 10:35:00 [27030]
vjanos | 5568    2015-09-16 10:56:00 [27032]
Én is arra gondoltam, van belőle önthető, kétkomponensű.
Előzmény: zoli0302, 2015-09-16 10:52:00 [27031]
zoli0302 | 387    2015-09-16 10:52:00 [27031]
A poliuretán hab nem jó ?
forgácsolo | 2703    2015-09-16 10:35:00 [27030]
tudtok-e olyan anyagot hasonló mint akár a nikecel vagy polisztirol amit formába tudok önteni
Rasiel | 505    2015-09-16 04:52:00 [27029]
Tudna valaki valamiféle leírást küldeni az AvrStudio C fordítójához? Szeretném (kénytelen vagyok) megtanulni, de nincs miből.
Köszönöm előre is!
forgácsolo | 2703    2015-09-15 22:51:00 [27028]
valami egyszerűbb
Előzmény: zozo, 2015-09-15 22:34:00 [27027]
zozo | 5527    2015-09-15 22:34:00 [27027]
Hungarocell gyártás témához.
A 70-es évek végén még cégnél dolgozva terveztem autoklávot, amellyel csomagoló sarokidomok készültek. A lényege, a hungarocell alapanyag gyöngy formában kapható, amelyet az autoklávba raktunk, majd a száraz gőztől szétrobbantak a gyöngyszemek, mondhatni egymásba robbantak. Rengeteget kísérleteztem vele, hogy mennyi anyag kell bele, mekkora gőznyomáson a legjobb a hatásfok stb. Szóval ez az útja eléggé macerás, nem beszélve a gőz előállításáról.
Előzmény: forgácsolo, 2015-09-15 22:04:00 [27022]
forgácsolo | 2703    2015-09-15 22:27:00 [27026]
írtam
Előzmény: Törölt felhasználó, 2015-09-15 22:09:00 [27024]
Devecz Miklós | 2663    2015-09-15 22:13:00 [27025]
Egy megoldás
Törölt felhasználó    2015-09-15 22:09:00 [27024]
Más ügyben írtam. Várom a válaszod.
Török Tamás | 2045    2015-09-15 22:09:00 [27023]
Révész Ricsit kérdezd!
De létezik még talán aminocel , annó vízzel keverve habosodott (szigetelésre használták) ,de ez nem olyan kemény mint a nikecel...
forgácsolo | 2703    2015-09-15 22:04:00 [27022]
tudja-e valaki hogyan kell hugarocellt önteni?
tudom rosszul írtam mert nem tudom a pontos megnevezést, a lényeg az hogy van egy öntőformám és abba kellene valahogy olyan anyagot beletölteni mint amiből készülnek a gipszstukkó hungarocell utánzatok, remélem így már érthető, szóval tudja valaki ennek a technikáját és hogy milyen anyagból csinálják?
smalla | 1117    2015-09-15 00:17:00 [27021]
Nem tudom, majd holnap megnézem.
Előzmény: laacika, 2015-09-15 00:06:00 [27020]
[ 2.0535 ]
