A300 - DC szervó vezérlő
A300-as DC servo vezérlő építése.
Oldal 2 / 9 Ugrás ide:
ilkser | 19    2017-07-31 10:10:36 [370]
The driver is not running.
please help me...
ilkser | 19    2017-06-18 00:51:12 [369]
A300 schematics, top profil, block diagram.
elektron | 15859    2017-06-17 15:56:46 [368]
Can you show us the A300 schematic ?
Előzmény: ilkser, 2017-06-17 05:45:35 [366]
ilkser | 19    2017-06-17 05:54:33 [367]
I Use HEDS 9700 encoder.
http://electrathonoftampabay.org/www/Documents/Instruments,%20Sensors%20and%20Circuits/encoders/shaft%20encoder%209700.pdf
ilkser | 19    2017-06-17 05:45:35 [366]
I do not know the PID parameter setup settings.
But I can do Motor current and dither setup.
I will try with another motor and encoder
Do I need to mount R3 and R7 1K resistors?
I'm sorry, I'm using google translation
Előzmény: elektron, 2017-06-16 13:18:48 [365]
elektron | 15859    2017-06-16 13:18:48 [365]
Do you know how to setup PID parameters with the potmeters according to the user manual ?
Have you tested A300 with another motor and encoder ?
If you changed the motor wiring and it was constantly faulty then original wiring was correct.
I think if 5V is in the range 4.75-5.25 is OK the same is for 12V.
What does it mean "Encoder pull-up resistors are not available on the drive" ?
Előzmény: ilkser, 2017-06-16 04:12:45 [363]
ilkser | 19    2017-06-16 04:59:59 [364]
Test Video
ilkser | 19    2017-06-16 04:12:45 [363]
The cable connections are correct.
When I change the motor cables, the drive is constantly faulty.
5V output: 4.83V Is this probem?
12V output: 11,80V Is this probem?
On the schematic LM393N, I used the LM393P. Is this probem?
elektron | 15859    2017-06-14 13:53:00 [362]
Is this the first test with a newly made controller ?
Is wiring correct ? Check it.
Change motor wire red and black.
First
Előzmény: ilkser, 2017-06-14 03:28:14 [361]
ilkser | 19    2017-06-14 03:28:14 [361]
Hello there,
I have some problems with the operation of the A300 DC servo motor drivers.
I can control stepper motors with Mach3 program. But with the A300 dc servo drive I can not control the motors.
A300 dc is a red LED when I apply power to the servo. Turns off when I reset the drive. It's coming to grip the engine. When I run Mach3, there is no motive motion.
Can you help me.
Thank you.
sanka74 | 1561    2013-05-27 08:56:00 [360]
Köszi! Ezt én is megtaláltam...valami magyarra gondoltam....
Előzmény: D.Laci, 2013-05-27 07:50:00 [359]
D.Laci | 5546    2013-05-27 07:50:00 [359]
http://lmgtfy.com/?q=uhu-servo.de
Előzmény: sanka74, 2013-05-26 22:41:00 [358]
sanka74 | 1561    2013-05-26 22:41:00 [358]
Sziasztok! A UHU servo-nak hol lehet utánanézni?
Előzmény: svejk, 2013-05-26 20:51:00 [349]
n/a (inaktív)    2013-05-26 22:31:00 [357]
Elfogadom a nyákot, már nagyon kipróbálnám, hogy milyen is a servo a léptecsek után, de ez még egy kis szervezést igényel mert akkor már a mikrovezérlőket is el kellene juttatni hozzád, hogy egyszerre eltud őket küldeni.
Milyen email címen kereshetlek?
Előzmény: svejk, 2013-05-26 20:39:00 [348]
xsugix | 206    2013-05-26 21:47:00 [356]
Bakker, ezt ecseteltem neked a múltkor, hogy elő kellene állni már a szervó vezérlővel.
No, majd a héten megkereslek, segítek én is, csak legyen má' valami!
Előzmény: motion, 2013-05-26 21:27:00 [355]
motion | 606    2013-05-26 21:27:00 [355]
Nekem lenne egy már kész megoldásom max. 100V/20A-re (ha jól emlékszem)
Csak az a fránya PID...azzal pl. már nem kéne szenvedni.
Ja az árat egy felprogramozottra értettem, de még...áá majd holnap felhívlak inkább.
Köszi László hogy felajánlottad, nekem úgy is SMD-be kellene majd...(bár annyit nekem is megért volna )
Előzmény: svejk, 2013-05-26 20:09:00 [345]
Kristály Árpád | 3085    2013-05-26 21:01:00 [354]
Email ment...
Előzmény: sneci, 2013-05-26 20:58:00 [353]
sneci | 1763    2013-05-26 20:58:00 [353]
Így is jó, bár motion-ra gondoltam:):)
Dobj mailben egy postacímet, a pénzt majd lerendezzük a talin.
Kristály Árpád | 3085    2013-05-26 20:56:00 [352]
Hívlak reggel!
Előzmény: sneci, 2013-05-26 20:54:00 [350]
Kristály Árpád | 3085    2013-05-26 20:55:00 [351]
Megveszem!
sneci | 1763    2013-05-26 20:54:00 [350]
Nem címzem senkinek, csak ha már szóba került:)
Találtam a polcon egy P2Q V1.3 szerelt vezérlőt. Magi Istvántól vettem, hogy megnézzem működés közben, de nem került rá sor.
4000 Ft + posta ellenében megválnék tőle.
svejk | 33157    2013-05-26 20:51:00 [349]
Ja, és még kimaradt az UHU szervovezérlő, amit szintén sokan megépítettek itt a fórumon.
svejk | 33157    2013-05-26 20:39:00 [348]
Van egy gyári nyákom, ha kéred odaadom.
Előzmény: svejk, 2013-05-26 20:38:00 [347]
svejk | 33157    2013-05-26 20:38:00 [347]
Arra szerintem alkalmas.
A bajok 10-20A és 60-80V felett kezdődnek, de nem csak ennél, mindegyik hobby vezérlőnél.
Előzmény: n/a (inaktív), 2013-05-26 20:33:00 [346]
n/a (inaktív)    2013-05-26 20:33:00 [346]
Nekem egy 200W-os 42V 6,2A motorhoz kellene, ezt elbírná az eredeti nyák?
Ha motion csinálna belőle egy vezérlőt, arra érdemes lenne várni, bár gondolom ez nem a közeljövőben lenne.
Előzmény: svejk, 2013-05-26 19:21:00 [343]
svejk | 33157    2013-05-26 20:09:00 [345]
Ketten vettük meg egy fórumtársunkkal egy számomra jelentős összegért, csak azért hogy ne idegen kezekbe kerüljön.
Én sokat bábáskodtam a fejlesztésénél tesztelésekkel, jobb-rosszabb tanácsokkal.
Egyelőre ha valaki kér akkor ingyen felprogramozom, később sem tervezünk belőle meggazdagodni, de természetesen nem jönne rosszul ha apránként visszafolyna az ára.
Örülnék ha kihoznál belőle egy jó kis cuccot.
Beszéljünk róla...
A legnagyobb baj mégis az, hogy úgy látom lassan kifutó típus a DSPIC30F4012 mikrovezérlő.
Előzmény: motion, 2013-05-26 19:41:00 [344]
motion | 606    2013-05-26 19:41:00 [344]
Ez a quantum chip engem is érdekelne István.
Jól tudom, hogy te lettél a tulajdonosa?
Ha igen tudnál küldeni egy doksit róla? (árral mellékelve)
Azt hiszem egy nagyon fincsi kis vezérlőt tudnék belőle fabrikálni.
svejk | 33157    2013-05-26 19:21:00 [343]
Akkor a Quantum chip a barátod, szoftver oldalról rendben van, még Magi csinálta.
Kellene hozzá egy nagyáramú nyák, de az eredeti is hasznúlható kisebb motorokhoz.
Előzmény: n/a (inaktív), 2013-05-26 19:09:00 [340]
svejk | 33157    2013-05-26 19:16:00 [342]
Gyáriban DCS303 a Klavio-tól
Hobby vezérlők:
- Sneci
- Tibor45
- Kozo SMC3 klónja
- Quantum chip (ehhez kellene egy jó kis nyákot tervezni)
- meg biztos van még egy tucat
Előzmény: kozo, 2013-05-26 19:03:00 [339]
Miki2 | 2341    2013-05-26 19:12:00 [341]
Nézzél szét Itt
n/a (inaktív)    2013-05-26 19:09:00 [340]
Mi az, hogy elérhető árú? Minden bizonnyal könnyebb lenne a Klaviotól rendelni, de az nekem nem elérhető árú.
Az SMC vezérlővel szemezek most, de annak túl alacsony az encoder jelfeldolgozási sebessége.
Előzmény: svejk, 2013-05-26 18:58:00 [338]
kozo | 1853    2013-05-26 19:03:00 [339]
A márka !?
svejk | 33157    2013-05-26 18:58:00 [338]
Annyi, sok jobb, egyszerűbb szervo végfok van már elérhető áron, miért nem azok közül választotok?
n/a (inaktív)    2013-05-26 18:35:00 [337]
Aki nálam jobban fel van szerelkezve a nyák gyártásra az könnyedén megcsinálja. A galvanizálás hiányát meg kétoldalas forrasztással talán mindenhol orvosolni lehet. Nekem nem volt kedvem bevállalni a házi készítést.
Előzmény: elektron, 2013-05-26 17:45:00 [336]
elektron | 15859    2013-05-26 17:45:00 [336]
Házilag nem lehet ilyet marni ? Csak gyári lehet ?
n/a (inaktív)    2013-05-26 17:21:00 [335]
Úgy látom ez a A300 korszak lezárult, nem sok alapanyag van hozzá.
Előzmény: Lovi, 2013-05-26 17:04:00 [334]
Lovi | 732    2013-05-26 17:04:00 [334]
Engem is érdekelne 4 darab nyák.
n/a (inaktív)    2013-04-09 20:27:00 [333]
Nincs véletlenül valakinek 2db A300 NYÁK, vagy esetleg, kész panel.
krajnyakdani(kukac)gmail.com
guliver83 | 3241    2013-04-09 20:10:00 [332]
Ez biztos, hogy igaz! De szeretem az olyan áramköröket amit és rakok össze, eddig minden áramkört én raktam össze a gépemhez. Igaz, hogy sok tesztelés és sok IC éget ki de én csináltam! Már legalább egy hónapja szenvedek egy léptetőmotor meghajtóval mire vagy a 20 panel sikerült!
Előzmény: rekalaca, 2013-04-09 18:17:00 [330]
PSoft | 18696    2013-04-09 19:37:00 [331]
Ez így igaz,ahogy mondod!
Nálam,már több mint egy hónapja bizonyít a kis? PWM-es szabályzó,és mondhatom f@szán működik!
rekalaca | 550    2013-04-09 18:17:00 [330]
Bár nem engem kérdeztél.
Ez egy alap kapcsolás ehhez kellene egy teljesítmény kimenet.
Dcsabának van készen IGBT kimenettel 70-80! amper!
Három-négy ezer közt. Az alkatrészt nem veszed meg ennyiért.
Előzmény: guliver83, 2013-04-09 13:54:00 [329]
guliver83 | 3241    2013-04-09 13:54:00 [329]
Egy ilyen áramkör jó lehet az E240 szabályzására?
Most 63V DC-ről hajtom, de így nem tudom a fordulatot lejjebb venni és kellene hozzá egy szabályzó. Maró motorként megy háromszoros gyorsító áttétellel.
PWM kapcsolási rajz
Előzmény: svejk, 2013-03-06 16:08:00 [326]
Dodi | 12    2013-04-09 12:47:00 [328]
Szeretnék vásárolni egy kis teljesítményű DC-szervó vezérlőt. Nekem 50W -ig bőven elég lenne.
Ha jó áron volna A300, akkor az is megfelelne.
Előre is köszi.
korbendallas | 511    2013-03-06 16:16:00 [327]
köszi
svejk | 33157    2013-03-06 16:08:00 [326]
Az E240-ekhez 50-60 V.
Előzmény: korbendallas, 2013-03-06 09:44:00 [325]
korbendallas | 511    2013-03-06 09:44:00 [325]
Van 4db ilyen vezérlőm, most raktam össze. 250W-s sanyo denki vagy hogy kell írni motorjaim vannak, meg e240-k is. Mekkora tápegység kellene hozzá? Hány V-os? Hány A-s? Előre is köszönöm a segítséget
VTamás | 1195    2013-01-14 17:53:00 [324]
Köszönöm ismét!
Megyek is,most már szerencsétlenkedhetek tovább a műhelyben...
Előzmény: svejk, 2013-01-14 17:51:00 [323]
svejk | 33157    2013-01-14 17:51:00 [323]
Igen.
Előzmény: VTamás, 2013-01-14 17:49:00 [322]
VTamás | 1195    2013-01-14 17:49:00 [322]
Na,az jó!
Akkor ugyan úgy sorba köthetőek vegyes használatban,mintha csak egyik fajta vezérlők volnának?
Nyomógomb indításhoz 2 s-ig +5V-ra,másik gomb GND-re
Előzmény: svejk, 2013-01-14 17:34:00 [321]
svejk | 33157    2013-01-14 17:34:00 [321]
Kompatibilisek, hiszen sosem volt titok, hogy 95%-ban ugyan az.
Előzmény: VTamás, 2013-01-14 17:29:00 [320]
[ 1.0362 ]
